Winter Storage
Old 10-29-2011, 03:35 PM
G_954rr's Avatar
Cool Winter Storage
I was gonna change the coolant in my toyota, and found out that I need special red coolant. Made me wonder, did I put the correct anti-freeze in my cycle; I used prestone ethlyne glycol extended life with distilled water. I wouldnt be so concerned except its gonna sit for a while. Anybody have a take on this? I waxed it, cleaned it, changed the fluids, checked the parasitic drain... had a large amp draw... turned out to be alarm, even when it was off...to check amp draw disconnect neg batt cable put ammeter between cable and batt terminal, check max amp draw with every thing off, if excessive draw(check manual), disconnect fuses one at a time till amps fall into range and then follow that circuit. I read about others putting oil in spark plug holes, and better to never start it until its ready to ride again. As for me, Ill run it once a week to get out condensation, and keep everthing with nice coat of oil. Keep tires of the floor with bike stands. Can anyone more familiar with storing bikes list what they do, so we can keep it in mind.
Old 10-29-2011, 05:45 PM
Conrice's Avatar
my biggest thing for people that are storing bikes is the oil. fresh oil is a must. burnt oil has corrosive acids in it that affect the internals.
fuel stabilizer.
tire care (correct psi, bike off the ground (or you move it daily) to not have flat spots).
take the battery out of the bike, slow trickle it every few weeks
as far as oiling the plugs, people do that in order to put oil into the cylinder so that the cylinder itself doesn't have a chance to rust, which is not a problem on the 954, so don't worry about it.
Old 10-29-2011, 06:01 PM
G_954rr's Avatar
What about the prestone extended life? The manual says highgrade ethylene glycol with protectants
Old 10-29-2011, 07:48 PM
Conrice's Avatar
so long as you're not mixing coolants, i'm sure you're fine
Old 10-31-2011, 10:57 AM
exz5string's Avatar
I use straight engine ice in mine, no issues. Other steps same as everyone else said, fresh oil change, fuel stabilizer, maybe even a can of dry gas, and put it up on stands. I personally take the battery into my house during the winter months, garage is not insulated or heated so it gets butt cold out there, I take re-install the battery and start the bike every couple weeks. Getting ready to do all that myself since I figure I'm done riding until April, damn winter!
Old 10-31-2011, 04:47 PM
Conrice's Avatar
i hear ya, i feel bad for all you guys up north.
cjones120201
11-19-2012 12:31 PM
alysiak00
11-19-2009 11:20 AM
OKIEZAC
09-11-2007 12:19 PM
RepSolRider
04-25-2006 01:03 AM
05Tribal
12-21-2005 03:16 PM
Quick Reply: Winter Storage
