Told it’s the stator
Old 08-26-2018, 06:59 PM
Steven Lindsey's Avatar
Default Told it’s the stator
Oil leaked out and smelled like gas. Also the plastic diaphragm (looks like primer bulb) is cracked on whatever part. Any ideas
Old 08-26-2018, 08:14 PM
74demon's Avatar
I don't understand the question.
The thing in the cover is your stator. A little oil will leak out if the bike isn't leaning on the right side. If it smells like gas, that's a different issue.
What plastic diaphragm?
Old 08-27-2018, 02:55 PM
servo motor cap is what I was referring to as plastic diaphragm.
Old 08-27-2018, 02:57 PM
as to gas smell... fuel pump doesn't prime and have tried starting it but doesn't get spark. So could it be just flooded?
Old 11-22-2018, 10:25 PM
Webby64's Avatar
fuel pump not priming? & getting no spark? go over the suss wiring with a multi & look for groundings, & if that"s all OK ? The HISS set up wont prime the fuel pump & let no spark to the engine when the ecu detects a fault. Check the fuse box ignition fuse, & diaod. C.W
cbr600f3covina
05-10-2009 05:13 AM
p8ntballer99
03-31-2008 02:08 PM
4CN Air
09-09-2007 04:16 PM
candyblueRR
06-27-2007 02:27 PM
BlkCBR600
12-31-2004 03:45 AM
Quick Reply: Told it’s the stator
