Told it’s the stator
https://cimg2.ibsrv.net/gimg/cbrforu...61fe078af.jpeg
Oil leaked out and smelled like gas. Also the plastic diaphragm (looks like primer bulb) is cracked on whatever part. Any ideas |
I don't understand the question.
The thing in the cover is your stator. A little oil will leak out if the bike isn't leaning on the right side. If it smells like gas, that's a different issue. What plastic diaphragm? |
Originally Posted by 74demon
(Post 1317049)
Originally Posted by Steven Lindsey
(Post 1317081)
servo motor cap is what I was referring to as plastic diaphragm.
fuel pump not priming? & getting no spark? go over the suss wiring with a multi & look for groundings, & if that"s all OK ? The HISS set up wont prime the fuel pump & let no spark to the engine when the ecu detects a fault. Check the fuse box ignition fuse, & diaod. C.W
