Told it’s the stator
Old Aug 26, 2018 | 06:59 PM
Steven Lindsey's Avatar
Default Told it’s the stator
Oil leaked out and smelled like gas. Also the plastic diaphragm (looks like primer bulb) is cracked on whatever part. Any ideas
Old Aug 26, 2018 | 08:14 PM
74demon's Avatar
I don't understand the question.
The thing in the cover is your stator. A little oil will leak out if the bike isn't leaning on the right side. If it smells like gas, that's a different issue.
What plastic diaphragm?
Old Aug 27, 2018 | 02:55 PM
servo motor cap is what I was referring to as plastic diaphragm.
Old Aug 27, 2018 | 02:57 PM
as to gas smell... fuel pump doesn't prime and have tried starting it but doesn't get spark. So could it be just flooded?
Old Nov 22, 2018 | 10:25 PM
Webby64's Avatar
fuel pump not priming? & getting no spark? go over the suss wiring with a multi & look for groundings, & if that"s all OK ? The HISS set up wont prime the fuel pump & let no spark to the engine when the ecu detects a fault. Check the fuse box ignition fuse, & diaod. C.W
cbr600f3covina
May 10, 2009 05:13 AM
p8ntballer99
Mar 31, 2008 02:08 PM
4CN Air
Sep 9, 2007 04:16 PM
candyblueRR
Jun 27, 2007 02:27 PM
BlkCBR600
Dec 31, 2004 03:45 AM
