stolen bike wont start
Old Mar 17, 2011 | 05:28 PM
Stoner's Avatar
Default stolen bike wont start
I started piecing together my 954 and i have reached the point where the engine turns over but will not start. I will list what ive had to do and maybe somebody will recognize something that is causing it not to start.
First off the bike was stolen with no key, they removed it from my garage and threw it in the back of a truck. When i got the bike back they had spliced 3 wires from the ignition (trying to jump it i assume) I replaced start/ stop switch and ingition.
Also stolen were 2 coil packs the air filter along with the screws an airbox gasket. They beat it up pretty bad so there was a lot of cosmetic damage.
I cant find anything else missing that will cause it not to start, so im looking for ideas on other possible causes. Could jumping it have done something to the computer or other ingition component? I have only a small amount of gas in it (maybe a gallon) is that enough to start it on it was completely drained.
I assume the coil packs were good that I bought. Sorry for the long post just looking for some starting places.
Chad
Old Mar 17, 2011 | 05:33 PM
Summoned's Avatar
see if it has spark! be safe but i like to check my in the dark to see if the plug is sparking!!! that will be a big help and a good starting point!
hope this helps
Old Mar 17, 2011 | 05:41 PM
Kuroshio's Avatar
*whew* title was a little misleading. Had me thinking you were asking how to start a ride you stole
What she doing when you try to start it? Do you have lights and dash? Does she crank but not catch? I'm not familiar with the 929 so someone with more knowledge about the fuel system can ask the normal questions (fuel pump, if it has one, prime / start pumping?)
Old Mar 17, 2011 | 05:52 PM
moosestang's Avatar
Check the tip over sensor. Does the fuel pump prime? I think it won't prime if the tip over sensor is tripped, but I could be wrong.
Old Mar 17, 2011 | 06:41 PM
Stoner's Avatar
Wheres the tip over sensor, this thing was abused pretty bad in the 24 hours it was gone. Yes the fuel pumps sounds like it is priming/pumping.
I am planning to check the spark next.
Thanks for the replys, I did the title that way to get peoples attention....so far its worked
Old Mar 20, 2011 | 08:12 PM
Stoner's Avatar
Finally got my 954 to start, all the spark plugs were lose (think they tried to thieve those too) Ran thru several checks started to test the coils and inspect the plugs thats when we put them back in and made sure they were tight crossed our fingers and hit the start button. Fired right up, now all I need is head light housing, blinkers plastic, brake fluid resevoir and a lot of bolts.
Thanks for all the tips and suggestions.
CBRbanas
Mar 3, 2012 11:52 PM
motorhorse
May 11, 2009 07:10 PM
tagger609
Jun 27, 2008 02:09 PM
subestol12
Dec 31, 2007 05:20 PM
gixxereater
Jul 30, 2006 04:35 AM
