serious issues
Old Jun 21, 2008 | 01:05 AM
capinsober's Avatar
Default serious issues
OK so today after work I wanted to shine the bike up alittle bit so I took it to the car wash, like I have done sevral times, I usually just lightly go over the bike with the power washer. I dont know how it happend but my power commander got soaked, so it felt like my bike was olny running on 1 piston, it was bellowing white smoke ,and went through a gallon of gas in about 5 miles.when I got home i took it apart let it dry, it runs alot more normal except there is still alot more white smoke than normal. So I dont know what I should do, my power commander is a tfi I dont thnk that it hooks up to a pc, or i did not see a usb port, can any one tell me how to get my girl back to normal?
Old Jun 21, 2008 | 08:00 AM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: serious issues
I would try completely unhooking it from the bikes main harness. If it ran that poorly though you may have fouled out your plugs too.
Old Jun 21, 2008 | 09:00 AM
cbrRick954's Avatar
yeah, first step is to disconnect it and see where you stand.
with cell phones, if you submerge them, you can disconnect the battery, and put it in a bowl of uncooked white rice to soak the water out of it before it corrodes and does damage to the phone's electronics.
it shuold work with a pc as well. try that
Old Jun 21, 2008 | 09:18 AM
txsmainevent's Avatar
I know my plugs went out recently, and it sounded like a lawnmower and ran like ****...... couldnt find the plugs no cheaper than 17.99 a piece so about 70.00 bucks later she was tight. You should definatly take a plug out to check it out.
Old Jun 21, 2008 | 09:52 AM
capinsober's Avatar
That sounds like a good idea, I took her out this morning, and she is running close to normal, the power commander needed to dry, I will look into injectors first thing when I get off work thanks guys
Old Jun 21, 2008 | 11:56 AM
Hcstreetriding's Avatar
ORIGINAL: pimpncbr954s
If you do replace the plugs, NGK iridiums on ebay are about 10 bucks a piece. sounds like it just needed to dry though
mooseboy
May 21, 2011 03:11 PM
ddavis17
May 21, 2011 11:51 AM
SparkeeVR4F4i
May 13, 2011 04:06 PM
mk4
Apr 3, 2011 12:22 AM
05CBR600F4i
Feb 6, 2011 08:40 PM
