Red Light Flash and Loss of Power!
Old Apr 2, 2009 | 03:03 AM
Vince954's Avatar
Default Red Light Flash and Loss of Power!
So I was riding around my neighborhood earlier today and everything was running ok. I was in 2nd gear with steady throttle then all of the sudden really fast the bike losses power and the red light turned on for a second. I pulled over trying to figure out wtf just happened, then I start going again. This time the same thing happens, but the bike dies after loss of power. Any ideas?
02 CBR 954 10.6k miles no mods
**Bike was sitting for a year or so, I drained the gas, oil, etc, and haven't noticed anything to strange, although the chain is a little loose.
Old Apr 3, 2009 | 05:38 PM
Todd84's Avatar
Does the red light blink? How many times does it blink?
Old Apr 4, 2009 | 12:42 AM
Vince954's Avatar
It was just solid for about 5 seconds, then it went away, it felt like the bike wanted to die... the lights were dimming etc
Old Apr 4, 2009 | 04:29 AM
Shadow's Avatar
Could it be..........the oil pump ?
I hope not...............
Strange.........
Old Apr 5, 2009 | 11:18 AM
Todd84's Avatar
Loss of power? Like maybe the battery cables aren't tight? Maybe check those first.
Old Apr 7, 2009 | 02:38 PM
Vince954's Avatar
Battery cables are pretty tight... the ****er did it again to me going up an over pass it wanted to die and i hit the throttle and it wasn't doing ****, the rpm kept dropping to 0... i got over the overpass and was sitting at the light, and the engine died, the lights etc were still on though... and then today i was in mid turn and the engine cut off and the rear wheel locked on me.
Does it sound like it could be the spark plug causing the engine to stop getting power?
Old Apr 9, 2009 | 08:44 PM
jason jones's Avatar
Exclamation Same here dude
I was riding mine today on the hwy and after going about 100 and slowed down it did the same thing. Whats the deal? Could it be the charging system? I just have not had the time to take it to the shop just want a idea before i do.
Old Apr 18, 2009 | 10:37 AM
saetneta's Avatar
Same thing happened to me. I'm going to tinker around before I get it to the shop. If you go to the shop, would you please share your findings?
Old Apr 18, 2009 | 10:57 AM
PlayfulGod's Avatar
sounds like a short...
Old Apr 18, 2009 | 04:28 PM
saetneta's Avatar
This was much easier than I thought.... I knew batteries were important, but I didn't know a lose connection could cause backfires, the FI light and the engine dying at high rpm. Anyway, I pulled off the seat and found that one of my battery connections was lose. I recently installed a battery tender and I think the extra line on the battery helped the screw work lose. I tightened everything and the bike works great. I hope your problems are as simple to fix as mine.
Colombo
Jul 10, 2014 12:49 PM
CCollins799
Mar 12, 2012 04:30 PM
chestnut1011
Sep 16, 2008 07:59 PM
tvn954
Aug 28, 2008 02:09 PM
theisen61287
Jul 6, 2006 02:05 AM
