re-start suggestions
Old Nov 10, 2008 | 12:58 AM
jsuar039's Avatar
Default re-start suggestions
hi I just recently got my riders licence and I now own a CBR 954 that i got from my brother. he took off all the plastics and did an insane paint job on it, ill post up pis when its all assembled. my question to all of you out there is that, the bike has not been started in about 3 months, my brother kept the maintenence up to date the bike has now 17k miles and the spark plugs and the air filter have never been changed. i bought new oil for it but im not sure if there is anything else i should do before i start it up. thanks for your suggestions.
this is her now....
[IMG]local://upfiles/31413/E0A547B1E31F4E16AFBECC54E6A1ADD0.jpg[/IMG]
Old Nov 10, 2008 | 02:15 AM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: re-start suggestions
3 months, no biggie, fire it up. As far as routine maintianace, i would do oil change if needed, clean, lube, and adjust chain, check tire pressure. If you are so inclined, if the plugs have never been done, that would bea good idea, also maybe run some seafoam thru her, oh and maybe bleed the brakes if he hasnt done that in a while.
Old Nov 10, 2008 | 09:13 AM
txsmainevent's Avatar
While the tank is off you should do the plugs, Trust me its alot easier with the tank completely removed than propped up. I went 25K on the same plugs but in your situation the tank is off so do it now. 3 months is nothing just as long as you let the bike get to operating temp and you take it easy for a few feet. TK covered it pretty much, Just do a complete walk threw of the bike checking all the fluids and inspecting everything.
Old Nov 10, 2008 | 07:26 PM
SurfnSCal's Avatar
I say since you have the tank off, make sure you just drain what ever fuel that was in there and put in some fresh gas. I know here in Cali the fuel is really crappy and doesn't last long at all during storage. I would also do the plugs, they are recommended at 16000 miles and since you just have to remove the air box, why not since it would be so easy right now. I say maybe even do a quicky oil change without a filter, just get some fresh oil in there get it nice and hot and then do a real oil change with good quality oil. But having it sit for only 3 months you don't have to worry about much. Now if it was 3 years then you'd be in trouble. Well good luck on the bike
Old Nov 16, 2008 | 10:19 PM
jsuar039's Avatar
i started the bike today it started perfectly the first time...
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
Grlzridet0o69
Feb 13, 2007 01:03 AM
