Proper Shifting
Old Aug 7, 2011 | 06:36 PM
FLATBLACK740's Avatar
Clutchless upshifts r better!! As conrice stated do ur research! I've been doing it 20 yrs. Much smoother and easier on clutch wear. Imo much easier 2!
Old Aug 7, 2011 | 10:23 PM
letsride's Avatar
Originally Posted by Dazed
I don't think your method is right conrice, the clutch is on the bike for up shifts and down
I don't understand why people ask for advice and when they get it they say you are wrong.If your way works for you then continue to use it.
Old Aug 8, 2011 | 12:51 PM
Ironhead's Avatar
Originally Posted by Conrice
no clutch on the upshifts. its been proven to actually be smoother than shifting with a clutch.
pressure on the shifter, blip the throttle... next gear please, thank you
+1! To the OP....You have asked a very Technical question. To Understand the responses given. Go to your local Trackday event and just Listen to the Bikes as they pass. Performance Riding is not a simple pull on the clutch task. Simple Fix to this Question would be a Quick shifter.........
Old Aug 8, 2011 | 03:19 PM
TireFryer704's Avatar
I don't use mine sometimes either....especially when just cruising one-handed.....just let off the throttle a lil and pop it up.....there is no grinding or anything so why would you assume damage is being done? I also could do that with my 02 Mustang GT....just do it at the proper RPM and it should slide into gear.
Old Aug 8, 2011 | 05:21 PM
moosestang's Avatar
our transmissions are not like the ones in your car.
Yeah, they don't last as long and aren't nearly as smooth. Plus they share oil with the engine.
I always use the clutch. How else would I pull the front wheel between shifts.
Old Aug 8, 2011 | 05:37 PM
Conrice's Avatar
ok, well, here's another way to think of it. what do you think a a quick-shifter does? it does the same thing, only i blip the throttle, and it momentarily interrupts the ignition. either way, it achieves the same thing with the transmission.
you don't hear anyone saying "oh no, a quick shifter will ruin your tranny".
Old Aug 8, 2011 | 06:20 PM
MadHattr059's Avatar
Well, as I said earlier, it's a valid technique. If you're a 99.9% it's worth learning.
If you're not, why bother? Which-ever way you roll, at least you're Rolling. ;-)
Ern
Old Aug 9, 2011 | 12:40 PM
Ironhead's Avatar
Maybee I need a clutch for my 12 year old? Think It would help getting his *** into Gear?
Old Aug 11, 2011 | 02:42 PM
nmband13's Avatar
I used to use the clutch then someone brought up the idea of cloudiness shifting and so for three weeks now I skip the clutch and shift with a blip of throttle, makes shifting from 1-2 smoothe and no missing a shift like 1st to neutral
Old Aug 12, 2011 | 05:18 PM
CBR-Mike's Avatar
I have ridden over 400,000 miles on all brands of motorcycles since the early 70's and have been clutchless upshifting on all of them and have never ever had a transmission problem on any of them.
Shoot, I have 87,000 miles on my '05 FJR and have always upshifted with no clutch and that bike shifts as smooth as buttah..
The key is we are talking about normal everyday riding and not full power WOT runs - you miss a shift on one of those and you just might have some transmission issues.
Timr
Apr 9, 2011 08:11 PM
NE1000F
Mar 7, 2010 05:11 AM
ccain
Aug 15, 2009 06:41 PM
Measuredpath
Jun 25, 2009 03:03 PM
ibedanny
Apr 11, 2008 02:29 PM
