Proper Shifting
Old Aug 6, 2011 | 03:04 PM
Dazed's Avatar
Default Proper Shifting
Hey,
I was just wondering how you guys shifted your bikes. do you pull in the clutch switch up a gear and slowly let out the clutch and back on the gas? I saw a video with a guy on a r1 not using his clutch and he said he has been shifting with out a clutch for 10 K miles.... What is the proper way. Thanks!
Old Aug 6, 2011 | 03:33 PM
volcom440's Avatar
im a newer rider too so correct me if im wrong, but i believe your doing it the proper way, thats what i do anyways. shifting with no clutch eventually rounds off teeth or something like that.
Old Aug 6, 2011 | 03:52 PM
Dazed's Avatar
That's what I thought happened also.
Old Aug 6, 2011 | 03:59 PM
MadHattr059's Avatar
Up-shift...
A slight toe pressure against the shifter then pull in the clutch/ roll off the throttle.
As soon as you do that, give a firm "nudge" to make the shift. Release clutch/ roll
back on throttle.
Down-shift...
Pull in clutch while rolling off throttle, firm step down, release clutch while giving a 'blip' to the throttle. Smooth on the brake/s at the same time, matching RPM to deceleration.
"Throttle shifting can be a valid technique, I guess. Worked for me once,
after I broke a clutch cable, got me home. Other than that, it's a pretty useless
practice, imo. There's a reason they engineered your bike with a clutch.
Ern
Old Aug 6, 2011 | 04:57 PM
Dazed's Avatar
That post was very helpful thank you, That's how I have always shifted.
Old Aug 6, 2011 | 07:19 PM
volcom440's Avatar
Ern
couldn't say it any better.
Old Aug 7, 2011 | 08:25 AM
Conrice's Avatar
no clutch on the upshifts. its been proven to actually be smoother than shifting with a clutch.
pressure on the shifter, blip the throttle... next gear please, thank you
Old Aug 7, 2011 | 08:59 AM
Dazed's Avatar
I don't think your method is right conrice, the clutch is on the bike for up shifts and down
Old Aug 7, 2011 | 09:38 AM
letsride's Avatar
I don't use my clutch on up shifts either.Makes for much quicker up shifts,helpful at the track.
Old Aug 7, 2011 | 04:30 PM
Conrice's Avatar
do research... don't believe what i say, search it by trusted resources. look at sportrider magazine, they've done more than few articles on it.
clutchless upshifting is a very common and well used way of upshifting a motorcycle. our transmissions are not like the ones in your car.
and it is more smooth and actually (if done correctly) BETTER for your cogs.
