Problem....blahhh
Old May 30, 2009 | 04:35 PM
American Psycho 954's Avatar
Default Problem....blahhh
ok so the previous owner of my bike went down at about 20mph......the frame sliders saved the bike. After all the work ive done this winter, new frame sliders was one of the last things to throw on. Well last night taking the right one off (side it went down on) i noticed the bolt was tweaked pretty bad. Now the new bolt for the slider wont catch the threads. this is a problem, because now i dont want to ride it until thats fixed as it also mounts the motor. Whats the easiets solution? drill it out a little bigger and re-tap it? and just buy a bigger bolt? anu info would be great, its beautiful out here....and i just want to ride. thanx. P.S. new pix comming after this is fixed.....shes lookin sick.
Old May 30, 2009 | 06:57 PM
not_agn's Avatar
Try to find a tap that is the same as the bolt and try and chase the threads first. If that doesn't work you may have to drill it out and use a helicoil repair kit. Then you can still use the original bolt. Don't know if you could do that in the frame or not? You might have to rotate the motor down a little to get past the frame? I would try saving it first. Lee.
Old May 30, 2009 | 08:12 PM
Todd84's Avatar
Not the greatest solution but if you want to ride loosen the other motor mount bolts and move the motor so it catches the threads then try to get the other bolts lined up. Don't get too rough with it. If it doesn't work just wait. It is kind of a cobble way but it may work for you.
Old May 31, 2009 | 10:03 AM
Its all fixed now, we tried keepin it the same size....couldnt get it to work. So the bolts one size up now. It went alot smoother then i thought it would. thank god.
Old May 31, 2009 | 01:52 PM
shineynitelite's Avatar
Too Smart For My Own Good
Originally Posted by american psycho 954
its all fixed now, we tried keepin it the same size....couldnt get it to work. So the bolts one size up now. It went alot smoother then i thought it would. Thank god.
picssss
Old May 31, 2009 | 07:17 PM
im puttin them in the photo section right now
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
RR4me
Jul 19, 2006 09:03 PM
