Problem
Old Sep 4, 2008 | 03:49 PM
n_vanexel31's Avatar
Default Problem
To make a long story short, within the last couple of weeks my bike has been making a strange noise when up-shifting into third gear, as well as down-shifting into third. The noise is most prominent in lower RPMs.It's a sort of clanking coming from the chain. At first I thought it was just a little loose. I adjusted it, but it has not helped. I'm thinking it may be time for a new chain?It's just odd that it only happens in third gear. Has anyone else experienced anything like this?
Old Sep 4, 2008 | 04:21 PM
Trent954's Avatar
Default RE: Problem
^^ I've recently noticed mine doing something similar when taking off in 1st. Mine really sounds like I need to tighten my chain or something. Kind of a clicking noise coming from the back sprocket area. Mine is normally only when i take off from a dead stop though. It may happen in higher gears when I put pressure on the chain but I can't hear it if it is.
Old Sep 4, 2008 | 07:02 PM
kamikaze2899's Avatar
Default RE: Problem
How many miles on your chain and sprokets? Teeth on the sprockets worn? Last time chain was cleaned and lubed? Sometimes the axle can be off centered. I used to use the marks on the swingarm and axle to make adjustments, but found that they can be stamped from the factory a little off. I use a tape measure and go from the swingarm bolt to the axle to make sure both sides are the same. I'd check these first to rule them out. If not could be the cush drive. Good Luck.
Old Sep 5, 2008 | 12:33 PM
Trent954's Avatar
Default RE: Problem
How much play should there be on the bottom section of chain? I have been told 1/2" to 1". That sound correct?
Old Sep 5, 2008 | 09:57 PM
CBRinPDX's Avatar
Default RE: Problem
If you're only getting the noise w/ 3rd gear I'd expect the problem to be the 3rd gear not the chain.
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
