Oil change!!
Old Apr 10, 2010 | 08:25 PM
bbishop1895's Avatar
Default Oil change!!
It's time to change the oil in my 2002 954 with almost 21000+ miles. Is the a brand/type of oil that is better for higher mileage engines.
Old Apr 11, 2010 | 12:15 AM
bubba_finch07's Avatar
honda 4 stroke oil. If you want some real good stuff get the synthetic oil from honda
Old Apr 11, 2010 | 10:40 AM
letsride's Avatar
Use the search function,lots of threads already regarding oil.
Old Apr 12, 2010 | 06:40 PM
backdoc's Avatar
HP4 or HP4S from Honda are both good choices for your bike. I am currently running HP4S in my 954 and my riding buddy has always used HP4 in his 929.
Old Apr 12, 2010 | 06:46 PM
txsmainevent's Avatar
get the $1.00 a quart **** from the autoparts store......oil is oil f-it.....
Old Apr 12, 2010 | 07:03 PM
kilgoretrout's Avatar
Administrator - Retired
Rotella T or Rotella T6 (blue bottle synth) at walmart.
Great oil, easy to get, and it's cheap.
About $11 gal for the regular stuff or $20 for the synth.
Old Apr 13, 2010 | 03:09 PM
theskater101388's Avatar
i just changed to rotella synthetic this past oil change. hope it works all good. ive heard good things so i figure id try it.
Old May 22, 2010 | 10:42 PM
losymis's Avatar
oil aint jus oil
Old May 22, 2010 | 11:38 PM
skip954's Avatar
take a bucket out in the gulf and siphon up some ittl work fine
rotellat synthetic
been using it for about 2 years works great 20 buks a gallon
Old May 23, 2010 | 03:32 AM
KenB's Avatar
Aside from the difference between synthetic conventional oils, oil pretty much is oil. You'll always have some Amsoil dude try to tell you different but as long as you stay away from the energy conserving oils and use the viscosity stated in your manual, you'll be fine.
Some are concerned that the "energy-conserving" motor oils may have "friction modifiers" which will cause clutch slippage. Since that is a legitimate concern it is best to use only oils which are NOT "energy-conserving for motorcycles with wet clutches." Read the back of the container. It clearly identifies this. In general, only the very lighter oils, like 10w30, 10w20, 5w20, are energy-conserving. All 5w40, 5w50, 10w40, 15w40, 15w50, and 20w50 oils which I have found are not energy-conserving and can be recommended for general motorcycle use.
stealthCBR929
May 24, 2012 03:15 PM
89HurricaneF1
May 7, 2012 09:52 PM
michealparks
Feb 10, 2010 12:16 PM
fiveoh
Jul 8, 2008 10:43 AM
otisdr
Aug 7, 2006 06:51 AM
