Idol Surge
Old Apr 19, 2008 | 10:13 PM
Mikes03954RR's Avatar
Default Idol Surge
I got my CCT and my spark plugs changed a couple of weeks ago. I noticed quite a difference in performance with new plugs but I have a new problem. My idol surges withing a couple hundered RMP when I am at a stop sign or the bike is in neutral. Is this normal or do I have some type of other ignition problem?
Old Apr 20, 2008 | 12:16 AM
SurfnSCal's Avatar
Default RE: Idol Surge
are you running a pipe on it? You may need to get your throttlebodies synced. Also who knows maybe you have a vacuum line open.. i found the T fitting coming from throttle body to fuel pressure reg was broken and my idle was flucuating and I was having a lean miss at idle and just off idle. Well hope this helps. I know with pipes bikes seem to not be so smooth at idle. Well goodluck
Old Apr 21, 2008 | 10:27 AM
yah dude I have a slip on yoshi. Maybe I will throw my stock pipe on and see if there is a difference. Is my aftermarket pipe hurting anything?
Old Apr 24, 2008 | 11:06 AM
Does anyone else have any suggestions? The bike seems to run fine when in motion but when I start her up or am at idol, it fluctuates within a couple 100 rr's. This really worries me. Does anyone else have this problem with a bolt on yoshimura pipe?
pete 99
Aug 31, 2011 05:55 PM
stephen83
Oct 27, 2009 01:46 PM
Jreed8721
Jul 2, 2008 12:19 PM
hustlin1ninja
Oct 20, 2007 03:15 PM
upononef3
Jan 4, 2007 05:00 PM
