Surge at mid range RPm
Old Oct 20, 2007 | 12:27 PM
hustlin1ninja's Avatar
Default Surge at mid range RPm
I loked but there are a ton of posts on here. I have a 95 cbr f3 and in neutral or whatever gear i might be in it surges. In idle if held around rpm it bounces back and forth from 5500 drops to 4800-5000 and so forth. same as when I ride with it in gear at those numbers. after it heats up the problem seems to dissapear. Do you guy's think there is something possibly plugging up a passageway in the carbs causing a lean condition until it warms up and something like varnish thins out? [sm=dontgetit.gif]It's kind of boggling my mind. Thanks
Old Oct 20, 2007 | 03:15 PM
NickO's Avatar
Default RE: Surge at mid range RPm
My 96 was doing the same thing.....turns out the airbox was missing a gasket between the box and the carbs....also the carbs needed to be jetted for the slip-on pipe. Been running great ever since.
pete 99
Aug 31, 2011 05:55 PM
stephen83
Oct 27, 2009 01:46 PM
Jreed8721
Jul 2, 2008 12:19 PM
Mikes03954RR
Apr 24, 2008 11:06 AM
upononef3
Jan 4, 2007 05:00 PM
