How doe's one remove, the stopper ring and preload adjuster ?
Old Sep 20, 2009 | 09:34 AM
HERC's Avatar
Default How doe's one remove, the stopper ring and preload adjuster ?
Need some help, my bruthas
I can aready get the cap off and poured out the oil, that's fine, it's the stopper ring and preload adjuster. Just sitting here staring at the thing, wondering which sledge hammer to use on it..
Per the manual...
I just want to be sure, so I don't muscling the thing off and bunging it up...
Stopper Ring and Preload Adjuster...
Not to be confused with the handlebar stop ring.
Exposing the lock nut, atop the fork cap
So I can get to this point
Old Sep 20, 2009 | 10:27 AM
HERC's Avatar
Okay, nevermind, bros...
I got it...
I used a flat blade screwdriver and gently wiggled under the aduster and, bingo, a c clip flew across my garage....
Old Sep 22, 2009 | 05:26 PM
HERC's Avatar
It ended up being very easy..
I made my own driver and polished my fork leg with 800-1000 wet/dry sandpaper...No leaks yet at 80 miles.We shall see..
I'll try to make a video this weekend, when I do the right fork...
Old Sep 23, 2009 | 12:44 AM
theskater101388's Avatar
wait what did you have to take that off for, i dont even remember having to take that top piece from the "fork bolt" to change the fork seal.... unless you were changin somethin else or i just dont remember doing it.
Old Sep 24, 2009 | 05:59 PM
HERC's Avatar
To remove the lock nut, which in turn allows you to remove the spring and spring collar.
Old Sep 24, 2009 | 08:22 PM
what does that have to do with changing the fork seal tho? i didnt have to remove anything from that top assembly to change the seal IIRC...
Old Sep 27, 2009 | 02:22 PM
HERC's Avatar
You're right, you don't really have to but it's the only way to measure the fork spring and examine the the fork damper, plus drain the oil...
CBRfenatic93
Apr 19, 2014 11:42 AM
mbison83
Dec 29, 2010 02:47 PM
antatious
F2 Tech
Aug 23, 2010 05:31 PM
civicblade
Apr 23, 2009 08:24 AM
R1000
Dec 30, 2006 07:05 PM
