How do I change the speedometer from Miles to Kilometers
Old Jan 26, 2008 | 05:28 PM
Fab954's Avatar
Default How do I change the speedometer from Miles to Kilometers
Hi guys, I purchased a 2003 954 with a US salvage title. I checked the forum and a 2002 manual, but I cannot find how to change the speedometer from miles per hour ( MPH ) to kilometers per hour ( KPH ). I do live in Canada, and the conversion would be helpful.
Does anyone know how how I can change over the cluster to metric instead of imperial.
Thanks for the help.
Old Jan 26, 2008 | 05:36 PM
bobjoezx's Avatar
Default RE: How do I change the speedometer from Miles to Kilometers
hold the A button i believe.. maybe it's B i can't not remember but i know it's one of those.. do it when the bike is off but acc is on
Old Jan 26, 2008 | 06:07 PM
Mikes03954RR's Avatar
yeah thats all you should have to do is hold down a or b. I know that if you hold down a, it will reset your odometer
Old Jan 26, 2008 | 06:50 PM
bobjoezx's Avatar
ya one of them buttons will reset trip too.. play wiht buttons you will figure out what u need
Old Jan 26, 2008 | 09:36 PM
Fab954's Avatar
" Well that was easy !!! "
All fixed up.
Thanks guys, I said it earlier, this forum rocks !!!
Old Jan 27, 2008 | 12:33 PM
nikos's Avatar
ORIGINAL: bobjoezx
Yes. One resets the tripometer, and the other switches between miles and kilometers. I know this well because everytime I'm at a gas station, I turn the bike over to kilometers and/or change the temp gauge to celsuis. Every f'n time...
Old Jan 27, 2008 | 12:57 PM
VP's Avatar
VP
and just so you know you have to press both of them together to reset the clock... I recommend only changing the time while you're at the gas station after a fillup because I guaran-damn-tee you you're going to clear out your trip meter and go back to 0 miles...
Old Jan 28, 2008 | 11:47 AM
txsmainevent's Avatar
the A button (left side) switches from miles trip when u press it, if u hold it the trip will reset to zero. the B button (right side) will switch from mph/kph to kph/mph if pressed and if you hold it the temp guage will change from f/c or c/f. but reseting the clock is a pain in the ***!
Old Jan 28, 2008 | 12:43 PM
demonchild's Avatar
If you hold the A button it will....
I was going to answer it again just too make sure that it is totally clear. How did this thread get 7 responses on how to change the speedo?
Old Jan 8, 2010 | 12:23 AM
Lepperfish's Avatar
Feb 2010 ROTM
Not all bikes have this feature, the australian delivered models don't.. In the user manual it tells you which ones do and don't have this feature..
jlowellb
Oct 6, 2017 03:28 PM
Mad-AL
Aug 2, 2013 07:37 PM
OttawaCBRguy
Jan 16, 2011 02:09 AM
bananazx
May 3, 2008 06:26 PM
selecus
Apr 8, 2008 10:59 AM
