help with rebuild, can't get starter to crank
Okay I am rebuilding the wrecked red bike. I got a different motor and I am hooking it up. I can get the fuel pump to prime. All the lights work. I have a new battery. The motor will turn over by hand. Kick stand wire hooked up. I can't get the starter to crank.
Ok bike was in gear, but it still wont start. I unhooked the fuel pump but everthing else is hooked up. I can't get it to start. All I get is a loud click in the little box that the wire from the battery andthe wire from the starter connect into. Any ideas?
I feel stupid the starter is bad. I should have just bought the whole motor from you. I got a set of cases (cheaper, because of my stupid truck). I just got it to fire. Thanks I didn't even think to check the starter first
Jordon Bent
Jan 22, 2014 05:48 AM
kylesbored
Sep 10, 2006 07:36 PM
