help with rebuild, can't get starter to crank
Old Mar 16, 2009 | 11:47 AM
Todd84's Avatar
Default help with rebuild, can't get starter to crank
Okay I am rebuilding the wrecked red bike. I got a different motor and I am hooking it up. I can get the fuel pump to prime. All the lights work. I have a new battery. The motor will turn over by hand. Kick stand wire hooked up. I can't get the starter to crank.
Old Mar 16, 2009 | 11:50 AM
Todd84's Avatar
LOL I just realized it's probably in gear. I am an idiot. I will go check after I eat my lunch.
Old Mar 16, 2009 | 01:23 PM
Todd84's Avatar
Ok bike was in gear, but it still wont start. I unhooked the fuel pump but everthing else is hooked up. I can't get it to start. All I get is a loud click in the little box that the wire from the battery andthe wire from the starter connect into. Any ideas?
Old Mar 16, 2009 | 04:08 PM
not_agn's Avatar
Your sure the starter is good? What about that tip over sensor?
Old Mar 16, 2009 | 05:17 PM
Todd84's Avatar
I feel stupid the starter is bad. I should have just bought the whole motor from you. I got a set of cases (cheaper, because of my stupid truck). I just got it to fire. Thanks I didn't even think to check the starter first
Old Mar 16, 2009 | 07:46 PM
not_agn's Avatar
Need a starter, or do you have an extra? I have an extra if you need it.
Old Mar 16, 2009 | 08:40 PM
Todd84's Avatar
I had an extra
Jordon Bent
Jan 22, 2014 05:48 AM
nvanvlymen
Aug 2, 2011 02:19 PM
2001F4i
Feb 14, 2011 12:20 PM
cadillac curry
Apr 7, 2010 12:18 PM
kylesbored
Sep 10, 2006 07:36 PM
