help with rebuild, can't get starter to crank
Okay I am rebuilding the wrecked red bike. I got a different motor and I am hooking it up. I can get the fuel pump to prime. All the lights work. I have a new battery. The motor will turn over by hand. Kick stand wire hooked up. I can't get the starter to crank.
LOL I just realized it's probably in gear. I am an idiot. I will go check after I eat my lunch.
Ok bike was in gear, but it still wont start. I unhooked the fuel pump but everthing else is hooked up. I can't get it to start. All I get is a loud click in the little box that the wire from the battery andthe wire from the starter connect into. Any ideas?
Your sure the starter is good? What about that tip over sensor?
I feel stupid the starter is bad. I should have just bought the whole motor from you. I got a set of cases (cheaper, because of my stupid truck). I just got it to fire. Thanks I didn't even think to check the starter first
Need a starter, or do you have an extra? I have an extra if you need it.
I had an extra
