H.I.D Adjustment?
Old Jun 19, 2006 | 11:05 PM
8UR VET's Avatar
Default H.I.D Adjustment?
Whats goin on guys. I just installed my hid kit from www.xenonking.com I was riding it home from installing it and it seemed as if the light was pointed too low towards the ground. I was wondering if any of you all have installed this kit and or have any idea about how to adjust the beam. When I put it in the bulb was flush with the hole but it the light looks to low when im riding. any help is appreciated. Thanks
Old Jun 25, 2006 | 06:49 PM
driber's Avatar
Default RE: H.I.D Adjustment?
to adjust the vertical beam there is a adjustment screw by the upper right side of the center headlight area. It is in the center section. clockwise moves the beam up and counter moves it down. There is also a right-left screw located again in the center section but the lower left of the center headlight. clockwise moves the beam to the right of the rider.
Old Jun 27, 2006 | 08:54 PM
8UR VET's Avatar
thanks man. Ill go check it out.
Old Jun 29, 2006 | 10:13 PM
norcalgal954's Avatar
Thanks for the information. I am very techno challenged and I am needing a little more help! Are these screws located on the front of the bike when you are facing it looking at the headlights in front or below the instrument panel where the lightbulbs are inserted?
Also, what do I need to remove any parts to get to these screws?
Thanks!
Old Jun 30, 2006 | 06:19 PM
driber's Avatar
no need to remove anything to get to the screws. They are visable when you are sitting on the bike. If all else fails go to the nearest dealership and have them do it. They shouldn't charge anything b/c it takes about 10 seconds to do.
Old Jun 30, 2006 | 09:00 PM
Thanks very much for the info! I am really trying to learn more about my bike and do more stuff myself!!
72tx340
Jun 4, 2012 08:13 PM
J_Hairston
Sep 19, 2008 03:33 AM
psharma
Oct 2, 2007 10:08 PM
dirtysanchez
Aug 15, 2006 08:03 PM
