Coolant Leak
Old Mar 29, 2009 | 10:35 AM
Fast RR's Avatar
Default Coolant Leak
I have a small coolant leak and not really sure where its comming from. I have replaced the water pump gasket and it seemed fine. Just the other day I ran the bike and after I turned it off it was leaking again but from higher than the water pump. It only leaks when the bike is cold. I ran it, turned it off, and it leaked. Cleaned it up, ran it again, turned it off again and no leak. Like I said only when its cold, it get to normal temp. and its fine. Has anyone else had this problem and if so, how did u fix it? Thanks for reading and thanks for the help in advance.
gump
Apr 9, 2011 10:00 PM
Ragnar1x
Apr 9, 2011 09:29 PM
dominiksi
Feb 7, 2009 12:17 PM
phamtastic0
Feb 5, 2008 02:21 PM
mattyg
Apr 26, 2007 02:58 PM
