Coolant Leak
Coolant Leak
I have a small coolant leak and not really sure where its comming from. I have replaced the water pump gasket and it seemed fine. Just the other day I ran the bike and after I turned it off it was leaking again but from higher than the water pump. It only leaks when the bike is cold. I ran it, turned it off, and it leaked. Cleaned it up, ran it again, turned it off again and no leak. Like I said only when its cold, it get to normal temp. and its fine. Has anyone else had this problem and if so, how did u fix it? Thanks for reading and thanks for the help in advance.
