clogged fuel injector
Old Apr 28, 2012 | 08:45 PM
m320's Avatar
Default clogged fuel injector
Any one have any luck unclogging a fuel injector before having to take it out?
Old Apr 28, 2012 | 10:56 PM
Conrice's Avatar
that sucks, you should be able to find some fuel rails/injectors or something on fleabay for pretty cheap.
i've never gotten one unclogged succesfully, but i did try by hookin' up an injector to 12v and squirtin a mix of gas/seafoam into it. it was from an isuzu rodeo and it had been sitting in an open yard for over 2 yrs - so i don't think there was much hope for it - but you could try that.
you should be able to get something on fleabay for 20-30 bucks though if you wait til the right auction comes along
Old Apr 29, 2012 | 08:09 AM
moosestang's Avatar
How did you determine it is clogged while on the bike?
I was pulling my injector connections to check for corrosion and one of mine isn't like the other three. It doesn't have the same type of clip to release it and I couldn't get it to come off. Anyone have any insight into this? I should have taken a picture of it.
Old Apr 29, 2012 | 11:30 AM
m320's Avatar
#3 not firing, chk'd by getting it to operational temp and spraying header tube with water, pulled inj. last night but, can't tell if clogged by eye sight...Chk'd fuel pressure reg. and it's not leaking fuel. Getting ready to try something else before ordering new inj. ..........All my connectors are the same on my inj.'s don't know what to tell you about that....
Old Apr 29, 2012 | 04:46 PM
Conrice's Avatar
you sure it's not ignition? that would go before an injector should. and it's also a lot cheaper.
hook 12v to it and see if it sprays gas. use leads off of a test light or something hooked to your battery
Old Apr 29, 2012 | 07:14 PM
moosestang's Avatar
You can use a 9v battery to check the injector, just connect it in short bursts.
Old Apr 29, 2012 | 08:41 PM
m320's Avatar
Well I assumed it was an inj. because it was running find when I put it back under the cover and when I fired it back up three weeks later it was running on 3 cyl.'s.. Had to think back when I did this and realized what I did was my fault....Being in a hurry....Ended up being a fouled #3 plug...... Thks for the input guys...
Old Apr 29, 2012 | 08:46 PM
LasVegasHarley's Avatar
I have unclocgged one on an f4i. I used a can of carb cleaner with the red straw hose clamped to a short piece of vacuum hose, and then a short fuel hose over that and the injector. I used a 12v battery to open and close the injector. I also flowed the Carb cleaner backward through the injector as well as forward. It worked great and only took about 10 minutes.
outsider
Sep 12, 2012 09:02 PM
cBrentb
Sep 4, 2012 01:02 AM
x AtKiiNSoN x
Jan 3, 2012 12:07 PM
j8k0092
Jul 4, 2008 12:39 PM
RR Riden
May 30, 2007 05:19 PM
