fuel injector
Old Jan 3, 2012 | 12:07 PM
x AtKiiNSoN x's Avatar
Default fuel injector
hi all, im new to the forum.
i have a problem with my cbr 125 r7. the problem was that it just cut out on me, then the fi light would not light up nor would it turn over when the electric start was pressed. some how i solved this (was a faulty connection under the tank). but this bring me onto the current problem. the fuel aint getting into the carb. the motor works fine (spilt petrol all over the floor when the key was turned), the fuel line isnt blocked. my only thought is the small fuel injector thats connected to the carb. ive taken it apart cleaned it and everything but still wont let petrol through. but the reason i question this is because it was working before when i was testing for a spark and the end was wet. could this be the definite problem? if it is, is there any way i can get just the part i need without buying the full carb? the fi also shows one long light with two short ones (12) which is engine fault fuel injector. 12, 13, 14 and 15 are all the same error descriptions.
any advice would be greatly appreciated#
cheers
maliken
Apr 16, 2013 02:25 AM
honda42
Apr 16, 2009 11:33 PM
RR Riden
May 30, 2007 07:32 PM
RR Riden
May 30, 2007 05:19 PM
Danny74
Mar 18, 2007 11:25 AM
