FI light= bad fuel injector?
Old Apr 16, 2009 | 01:20 PM
honda42's Avatar
Default FI light= bad fuel injector?
My FI light comes on evey once in awhile just for a few seconds and then will turn off and wont come on the rest of the day. Does this mean i have a bad fuel injector or could it just be a bad plug or something?
Old Apr 16, 2009 | 01:34 PM
justasquid's Avatar
Its hard to tell with an intermitten problem like this. The bad thing is, you almost have to wait for it to get worse to find out for sure, unless your bike has been throwing codes.
What bike is it? If its and F4i, could be an early sign of the FPR going bad. Its a fairly common thing on that model. Its also quite common on other models as well, but the F4i seems to suffer quite a bit more. But as far as I know, I dont think the injectors were a weak link in the system.
does the bike run odd at all?
Is it hard to start?
Does it run rich?
Does it hesitate? If these things happen to the bike, or have become noticable and become worse, My first guess would be the Fuel Pressure Regulator.
Old Apr 16, 2009 | 01:39 PM
honda42's Avatar
Yes it is an 2002 f4i and thank you very much for your reply
Old Apr 16, 2009 | 11:33 PM
skoobydoobie's Avatar
pull the codes...at this point everything is speculation. Could be a sensor going bad or a loose plug, or as squid stated the FPR, or an injector sticking, could be a number of things. Pull the codes.
x AtKiiNSoN x
Jan 3, 2012 12:07 PM
RedWing1
Aug 29, 2009 07:18 PM
silverstreak
Jun 15, 2007 01:04 PM
RR Riden
May 30, 2007 05:19 PM
Funnyguy
Jul 25, 2006 06:55 AM
