Check engine?
Old Aug 25, 2009 | 07:04 AM
sargentronco's Avatar
Default Check engine?
OK so My check engin light has been comeing on...it spit out 3 long 5 shorty blinks, I think that Faulty EGCV and Air Intake Servo Motor.
Is that correct?
And Also does anyone know why after I spend 2 hundred something on orderin the part, now my check engin light hasnt came on since, Did I waste my money? Wats going on??
Old Aug 25, 2009 | 09:51 AM
letsride's Avatar
The 35 code is your servo motor.As far as the light not coming on anymore,I would save the new part for the future or try and sell it.
Old Sep 29, 2009 | 08:23 AM
Alright So it kept having the probleim. I replace the Servo And its either the same pr maybe worse, How do i jus make it stay open????
Old Oct 10, 2009 | 02:03 PM
letsride's Avatar
Install the new servo motor and do not install the cables.You mite also want to gut the exhaust valve or wire it open that way your light won't come on and you wont have to worry about it again.
Old Oct 10, 2009 | 04:55 PM
Why install the new motor if i dont hook up the cables???? And how do i know which way is open on the exhaust???
Old Oct 10, 2009 | 05:13 PM
letsride's Avatar
If your old motor is bad it will continue to throw the 35 code.With the new one you will eliminate the code.Take the left side fairing off,take the little cover to the htev valve and you'll see the cables going to it.Remove the cables,you will see the valve has two markings on it.Turn it to the left and align the markings in the down position and wire it down.Hope this helps you.
rpetro24
Apr 5, 2021 12:54 PM
joelluing
Jun 6, 2014 11:24 AM
xjoex
Jun 17, 2009 06:26 PM
eraser0
Dec 14, 2008 07:48 PM
1wheelwonder
Nov 3, 2008 07:20 PM
