Air filter removal
its simple and should only take you a half hour if you have good mechanical skills. remove your seat first. then remove the two bolts at the front of the tank. lift the tank up, being careful not to drop the bushings in the holes you just took bolts from, and use the prop rod that's on the underside of the seat to hold it up. The screws that hold the lid of the airbox are phillips head, and the ones towards the back will require a longer screwdriver. Once thats off the filter comes right out. Put the new one in, and put everything back together.
I went with K&N myself. No reason that I did other than their reputation.
http://cars.about.com/od/productrevi...g_knfilter.htm
that review backs up what I have always known. while the increase in power is not noticeable, there are benefits of the K&N. like only having to clean them every 10k miles instead of replacing them like OEM filters.
To me there's a certain undeniable science behind the fact that filtering decreases as air flow increases - basically if something's providing better airflow it's due to less filter media and thusly more particles passing through.
IMO, if engine designers thought that serviceable air filters were ideal they would have designed them that way and included it as part of a regular dealer service schedule to wring more $$$ out of people.
