954 fuel and ignition controller
Old Sep 7, 2014 | 12:53 PM
dusterdude's Avatar
Default 954 fuel and ignition controller
I have a 954 engine im putting in a drag frame to race,is there an aftermarket ignition and fuel controller i can use instead of the oe computer and will i need the oe computer for any other functions?thanks
Old Sep 7, 2014 | 05:40 PM
Conrice's Avatar
954 ECU + Power Commander IIIr is what you need. And it has to be the IIIr
OR
Megasquirt with a Dyna Ignition box.
Old Sep 7, 2014 | 06:16 PM
dusterdude's Avatar
Thanks conrice,appreciate the info
Old Sep 8, 2014 | 02:57 AM
mika_u's Avatar
Sept 2014 ROTM
If you don't have the oem ecu i would get an aftermarket ecu (msd, woolich, megasquirt etc.). If you do have the oem ecu any aftermarket piggypack unit will work ( pc3/5, bazzaz, rapid bike etc.). Is the motor stock? If it is you won't do anything with the ignition controller. Rapid bike has a unit with fueling and ignition controller and then there is the old pc3r. With pc3usb and pc5 you will need a ignition module which is sold separetly. Bazzaz doesn't have ignition controller so with that you will have to use dynatek etc. But these need the oem ecu. Isn't the megasquirt allso capable of handling the ignition with out any separate boxes?
Old Sep 12, 2014 | 08:16 PM
dusterdude's Avatar
Mika,yes the engine is stock and will probably stay that way for a year or two.thanks for the info
Old Jul 6, 2019 | 12:27 PM
dusterdude's Avatar
if i can resurrect this old thread,i have another question in the same ball park.so here we go,you gearheads that are familiar with chevy ls swaps,know that most swaps are done with factory computers and wiring harnesses.you also know that a lot of these harnesses are depinned to allow the user to remove certain systems to be removed from computer control.here's my question,can i depin the harness i have for my 954 drag only engine to remove things such as the bank angle sensor and kick stand sensor and any other i deem unnecessary to run the engine.of course this will be run with the stock honda computer.thanks
Jamesisthename
Feb 18, 2019 05:27 PM
Mitchell Pereira
Jul 5, 2017 06:44 PM
nickp123
Aug 20, 2010 08:23 PM
bignibb
Apr 10, 2007 12:47 PM
DrDRFT
Aug 9, 2006 04:32 AM
