954 cylinders
Old Mar 19, 2011 | 12:28 PM
JD954RR's Avatar
Default 954 cylinders
I have my 02 954 motor apart, cylinders and pistons all measure within wear limits. There is some scoring on the front and back of the cylinders, should I hone them? Can I hone them? Or should I put new rings in a call it good? Thanks in advance for your help.
Old Mar 19, 2011 | 01:02 PM
itlnF4I's Avatar
honeing is simple and cheap, id just do it because everythings out in the open.
Old Mar 20, 2011 | 01:15 PM
Conrice's Avatar
a lot of people told me that i wouldn't be able to hone my cylinder walls because of the nikasil lining....
they honed up real easy with a basic automotive hone and some brake cleaner/wd40. go for it.
my walls were really scorred bad too, how close are you to the wear limits? if you're close, measure again after you hone and hatch.
Old Mar 20, 2011 | 04:25 PM
JD954RR's Avatar
Thanks for the info, that is what I was worried about was the coating. Did you use one grit or multiple hones? Not close to the limits, just some minor scoring on the front and back of the cylinders. Thanks again.
Old Mar 21, 2011 | 09:30 AM
Conrice's Avatar
i didn't use anything special. the hone i have is the kind that you use with a drill, and it has 3 grinding stones that are spring pressured, something like $15 from harbor tool and frieght.
how bad is the scoring? are you catching a fingernail in them when you run across the walls?
Old Mar 21, 2011 | 12:17 PM
JD954RR's Avatar
Not too bad on the scoring, don't exactly catch my nail but can feel it, and see it. Thanks again for the info.
noslack21
Feb 4, 2013 08:20 AM
snopro321321
Aug 27, 2011 04:59 PM
xiztence
Jun 22, 2011 05:24 AM
Nowherekid109
May 12, 2011 05:04 AM
g32bturbo
Aug 16, 2008 10:25 PM
