2nd gear difficulties
Old Oct 13, 2011 | 05:22 AM
itlnF4I's Avatar
shift drum is usually not the culprit. neither is the shift fork. the common culprit of a gear kicking back is rounded dogs from clutchless shifting from first to second and second to third. i went through it with my f4i, it requires new gears which DOES require the motor to be removed and the case split.
Old Oct 14, 2011 | 11:13 PM
ajzcamaro's Avatar
Originally Posted by MadHattr059
Try adjusting the shift pedal. Usually lowering it some helps. Your foot has a limited range of movement and if it's too high, you aren't able to lift it that last bit it needs for a smooth shift.
Ern
I was going to say the same thing. I was having problems with shifting into 2nd gear until I adjusted the shift pedal. I lowered it just slightly and have yet to have a problem.
Old Oct 15, 2011 | 12:34 PM
Omaha rider's Avatar
Thanks guys I will try this
Old Oct 16, 2011 | 09:29 AM
moosestang's Avatar
Originally Posted by Desertfox223
I agree with Conrice on the sound made in neutral, correct me if im wrong but isn't it doing this because everything is probably just freely spinning without added force of being in gear?
Yes, my car does the same thing.
Trent Dog
Jul 9, 2012 06:32 PM
dwellernet
Apr 11, 2008 04:35 AM
dwellernet
How-To: Mechanical
Mar 3, 2008 11:36 AM
panosbouras
Jul 23, 2007 06:49 PM
