03 954 died while riding
Old 07-13-2018, 10:05 PM
Steven Lindsey's Avatar
Default 03 954 died while riding
Battery was extremely hot and smelled like eggs. Got her home and now FI and ind fuses blow? Unplug speed sensor and have dash light's will crank. Checked numerous connections with ohmmeter. HELP ME PLEASE
Old 07-14-2018, 12:35 AM
CaBaRet's Avatar
Hi Steve, would check out your reg/rec and fault find, heres a fault finding flow chart, would have a look at your battery as well ,might need a new one,would unplug the connector to the reg/rec
Old 07-15-2018, 05:39 PM
thanks will start what looks to be a frustrating process. Oh have a brand new battery. Will be a few days but will post as I progress.
Old 08-02-2018, 09:00 PM
New battery and rr. Fuel pump didn't prime blows fuses when black box is connected cranks that's it
Old 08-09-2018, 02:17 PM
kahlilj's Avatar
can't understand... is it fixed? or did you replace the battery and reg/rec but it was still not working? was the problem with the fuel pump?
Old 08-09-2018, 02:36 PM
It isn’t fixed. I installed a new battery and RR. This weekend going to look at ignition/kill switch wires. I haven’t messed with the fuel pump. Need to find short first to stop fuses from blowing. If that isn’t it off to the Honda mechanic.
Old 08-13-2018, 01:26 PM
Default Blue 12p connector
When I connect Bu 12p the FI/IGN fuse blows. Still no fuel pump prime BAS has jumper in it. Hopefully this has lowered the possibilities. A researching i go.
Old 08-14-2018, 11:26 AM
FIREWOLF's Avatar
Hello hows it going Im a brand new member and also a new honda tech. so what have you done and what results so far? are you in Missouri by chance?
Old 08-16-2018, 04:48 PM
New battery and RR.
aireq
12-30-2018 02:48 PM
167
06-19-2013 10:56 PM
babyhydro
01-26-2010 06:12 AM
Stevus
06-06-2009 11:25 AM
tonyB11
10-16-2007 12:38 PM
Quick Reply: 03 954 died while riding
