-   CBR 954RR (https://cbrforum.com/forum/cbr-954rr-21/)
-   -   03 954 died while riding (https://cbrforum.com/forum/cbr-954rr-21/03-954-died-while-riding-157913/)
Steven Lindsey 07-13-2018 10:05 PM
Battery was extremely hot and smelled like eggs. Got her home and now FI and ind fuses blow? Unplug speed sensor and have dash light's will crank. Checked numerous connections with ohmmeter. HELP ME PLEASE
CaBaRet 07-14-2018 12:35 AM
1 Attachment(s)
Hi Steve, would check out your reg/rec and fault find, heres a fault finding flow chart, would have a look at your battery as well ,might need a new one,would unplug the connector to the reg/rec
Steven Lindsey 07-15-2018 05:39 PM
thanks will start what looks to be a frustrating process. Oh have a brand new battery. Will be a few days but will post as I progress.
Steven Lindsey 08-02-2018 09:00 PM
New battery and rr. Fuel pump didn't prime blows fuses when black box is connected cranks that's it
kahlilj 08-09-2018 02:17 PM
can't understand... is it fixed? or did you replace the battery and reg/rec but it was still not working? was the problem with the fuel pump?
Steven Lindsey 08-09-2018 02:36 PM
It isn’t fixed. I installed a new battery and RR. This weekend going to look at ignition/kill switch wires. I haven’t messed with the fuel pump. Need to find short first to stop fuses from blowing. If that isn’t it off to the Honda mechanic.
Steven Lindsey 08-13-2018 01:26 PM
Blue 12p connector
When I connect Bu 12p the FI/IGN fuse blows. Still no fuel pump prime BAS has jumper in it. Hopefully this has lowered the possibilities. A researching i go.
FIREWOLF 08-14-2018 11:26 AM
Hello hows it going Im a brand new member and also a new honda tech. so what have you done and what results so far? are you in Missouri by chance?
Steven Lindsey 08-16-2018 04:48 PM
New battery and RR.
