worn clutch cable ?
Old May 22, 2008 | 08:07 PM
HAVOC's Avatar
Default worn clutch cable ?
hey guys qucik question for ya. i've noticed lately on my bike that the amount of play i have in the clutch lever has dropped dramatically despite tightening . also when im sitting at a stop light in 1st gear and holding the front brakes then release i can feel the bike wnating to move forward . im thinking this is a sign of a worn clutch cable but upon inspection i dont see any frays and its not broken. when i pull the lever i can pull it about 1.2 way before it even moves the cable (hence the play i refered to earlier)
so im hoping im right nod this isnt a problem with my clutch itself. but if im wrong please let me know. i haven't noticed any slippin of the clutch either.
Old May 22, 2008 | 09:34 PM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: worn clutch cable ?
Is it hard to pull in at all? I had one on my gsxr that frayed inside the tubing, could not see it at all. It started getting hard to pull in, then a few weeks later snap. It could also have stretched a bit over time, i would suggest checking your adjustment at the clutch, or in other words to make sure its ok, do it by the manual. Screw it in at the lever, adjust properly at the clutch cover, then fine tune it at the lever and see how it works. If that all seems good try replacing the cable, they are pretty cheap and only takes a few min to do.
Old May 22, 2008 | 11:31 PM
HAVOC's Avatar
well i ordered the new clutch cable should be here this weekend. it was actrually really really easy to pull . so im going to try replacing that and then adjusting at the clutch cover something ive never done before and see what happens
Old May 25, 2008 | 02:38 PM
HAVOC's Avatar
replaced clutch cable and bike works fine now
Old May 25, 2008 | 04:43 PM
TK954RR's Avatar
Jan 2009 ROTM
Good to hear
Old May 25, 2008 | 09:52 PM
RCR's Avatar
RCR
Sounds like it stretched, Mine is starting to get excessive also.
Zandaloo
Aug 22, 2013 03:26 PM
lsybert
Jun 25, 2009 11:07 AM
red stinger
Jul 19, 2008 12:17 AM
HAVOC
May 24, 2008 02:09 AM
cyber00677
Jun 23, 2007 06:17 PM
