Undertail eliminator!!! Common PROBLEMS!!!
Old Aug 15, 2006 | 11:07 AM
thesaint's Avatar
Default Undertail eliminator!!! Common PROBLEMS!!!
I have been reading through the forums a bit, because I just got a really good deal on a 929, and I am having issues with the integrated led tail lights on the undertail kit. I seem to have a little more luck than some people cause I can get the blinkers and the brake lights working, but it is either or! Either I can wire it to work with the blinkers, OR the brakelights, but when I wire it for both, it freaks out and the brakelights wont work, and the blinkers turn to hazard/Flashers. ANY help would be appreciated, or even a wiring diagram would be good if anyone can email one to me!!!
Old Aug 15, 2006 | 12:52 PM
johndoe's Avatar
Default RE: Undertail eliminator!!! Common PROBLEMS!!!
i got problems with mine to. my brake light works but my blinkers go crazy. i dont have any front blinkers (that could be my problem).
you dont need blinkers but you do need your brake light. use hand signals.
Old Aug 15, 2006 | 01:03 PM
thesaint's Avatar
I dont think your issue would be caused by not having front blinkers, when I was having issues with the rear lights, I took a break and installed the front blinkers, and I still have the issues in the back.
Old Aug 15, 2006 | 02:11 PM
jrocken's Avatar
Take a look at http://www.dansmc.com/shopmanual2.htm you might find what your looking for.
Old Aug 16, 2006 | 06:07 PM
wpowell26's Avatar
i didin't install it, but i don't have any problems with my undertail and clear alternatives led tailkit. my mechanic didn't say he had any problems with it either. are you using the clear alternatives light kit?
Old Aug 16, 2006 | 09:42 PM
telepathboy's Avatar
You can't actually wire a standard two-lamp tail light to work with both signals and brake light - it just can't be done without a integrator box. I bought an one from HardRacing.com a few years back (about $30). good luck
fella
Aug 24, 2010 01:22 AM
thef4i
Jun 4, 2009 01:28 AM
hondachris1994
Mar 13, 2009 08:05 AM
y0ukeun
Jul 6, 2008 09:16 AM
Platinumgv
Apr 20, 2007 08:28 PM
