Ticking??Is this common?
Old May 8, 2007 | 06:27 AM
medicbaldwin's Avatar
Default Ticking??Is this common?
I have 9400 miles on my 929. It's starting to make some pretty good ticking. I'm thinking valves, but I see a lot of no need to check until over 17k miles posts on here. Are 929's inherently noisy bikes? I've only had the bike for about 1 month. I changed the oil thinking and hoping it was just old oil, no die.
medic-b
Old May 8, 2007 | 10:55 AM
gixxereater's Avatar
Default RE: Ticking??Is this common?
Some bikes to have a tick......you might be hearing the injectors? They make a ticking sound. Most will probably tell you it's the CCT, but that seems pretty early to have that happen.
Old May 8, 2007 | 11:51 PM
What is the CCT? The tick varies with the revs of the engine. Most noticable between 3-4000 rpm. After 4k I don't notice it as much, but it could also be the wind hitting my helmet that drowns out the tick.
Any idea of the specs for the valve clearances??
Old May 9, 2007 | 02:10 PM
mark5009's Avatar
ORIGINAL: medicbaldwin
For the valve clearances, you can check the manual. There have been other recent posts that give the download location.
CCT = Cam Chain Tensioner
Old May 9, 2007 | 05:07 PM
SUPERMAN_ON_929RR's Avatar
Yes mine doing same thing if you take a stephascope to the left side you will find the source most likely. I plan on having the valves and chain (cam) done and hopefully it will be gone. I 'm trying to sell this thing I'll let you guys know.
Old May 11, 2007 | 04:41 AM
TheRomanSF415x's Avatar
mine ticks only when i first start it then after about 15 minutes it goes away.. i have about 11k on mine should i get the valves looked at?
Old May 13, 2007 | 12:07 PM
blown hemi's Avatar
you could try and see if higher octane of gasoline helps' that would tell you that the previous owner was running it hard or a higher octane maybe even run some fuel injector cleaner, also would think about getting a valve adjustment done...
Dazed
Feb 19, 2013 04:50 PM
inco9nito99
May 8, 2011 03:35 PM
FightingIrish
Jan 11, 2010 12:30 PM
bignibb
Oct 3, 2007 03:52 PM
K0NPHL1C7
Sep 16, 2007 08:28 PM
