striped spark plug hole any ideas for an easy fix?
Don't use Helicoil for this application. They're primarily for one-time use on part that will never come apart. Because in process of removing bolt, it'll invariably remove Helicoil with it.
You want solid insert that stays in 1 piece and resists being pull out. Install with super-strong heat-resistant threadlocker.
Might be too late to use this kit though as the stripping out Helicoil may have damaged hole and these inserts won't be tight enough.
