straight pipe?
Old May 25, 2006 | 06:58 PM
yp_urslf's Avatar
Default straight pipe?
ive seen 929s with just a straight pipe dumping out infront of the rear wheel, will that hurt the motor, or the performance of the motor?
Old May 26, 2006 | 06:41 PM
birde's Avatar
Default RE: straight pipe?
i've takin the muffler off and ridin like that, not sure if it damaged the bike but omg was it loud, had to be the lousest thing i've ever heard
Old May 26, 2006 | 10:49 PM
Y2K929RR's Avatar
You might screw up the valves that way.
Old May 27, 2006 | 07:38 AM
rippn's Avatar
Birde, ya !!!!!!!!!!!! deafening, it sure does wake up the nieghborhood !!!!!!!!!!!!!! I was buff'n out my tailpipe and smuffler, last week. I couldn't resist, start'n 'er up!!!!!!!!!!!! SCHWIIIING!!!!!!!!!!!
Therorys... Altho less back preasure helps at some rpms... it is serriously detrimental to the curves(power/torque) usualy make'n a "hole big enough to drive an elephant thru"!!!!!!!!!! Over scavenging(lack of back preasure) of the intake charge, is like fushing power down the drain(and gas). Probably would be good on the freeway, IF, the jetting were "spot on", but probably kill the low speed torque. Cops hear you always, leeding to ride'n slower, almost everywhere... no fun !!!!!!!!! The burnt valve gig, is a legit concern too. Tractability(ease of thottle roll on and ridability) would suffer too, probably becomeing whats referd to, as "notchy" Leading to alot more clutch, to ease transition, then leading to glazed plates and replacment, early. Possible lightening of front wheel in corners, fun, but not condusive to truely being smooth and fast. Then, that cop thing again... Clean and free, Ripp'n
cam and corona
Mar 1, 2013 08:13 AM
subyman1440
F2 Tech
Jan 22, 2012 07:42 PM
mcguire6799
May 28, 2011 11:16 PM
600four
Mar 25, 2009 11:43 AM
matt_m427
Feb 11, 2007 12:19 AM
