starter valves
Old Apr 1, 2008 | 04:39 AM
shizz's Avatar
Default starter valves
has anybody had problems with their starter valves or anything
Old Apr 2, 2008 | 01:41 PM
shizz's Avatar
Default RE: starter valves
ok i got my bike to kick over like it wanted to start by putting my fingers over thes holes on the throttle bodies does any body know about these
Old Apr 2, 2008 | 08:10 PM
mikey1297's Avatar
those are the buterflie valves they open when you gas up the throttle and letair in
what is a starter valve?
Old Apr 2, 2008 | 08:35 PM
vwmaniacvr6's Avatar
ORIGINAL: shizz
Think of balancing the carbs on an older 4cylinder bike, these do the same thing to fine tune the airflow between cylinders so they match. If they are way out of whack it can cause problems.If you think that is the source of your issues you'll need 4 vaccum gauges to hook up all at once and compare readings with the bike running. If your at a no-start problem again, you could try setting them to a default, but then you risk making things worse and will definitely need to balance them afterwords.
MindFk
Jun 28, 2012 08:00 PM
MindFk
Jun 27, 2012 11:54 AM
nvanvlymen
Aug 2, 2011 02:19 PM
EL Thorsby
Jun 1, 2011 03:04 PM
