starter switch problems
Old Jun 19, 2007 | 11:04 AM
95HondaCBRF3's Avatar
Default starter switch problems
alright everyonce and awhile when i flip the kill switch to start and go to hit the button nothing happens but then i sit and keep pushing the button and eventually it will turn the starter and start the bike this has only happened a few times while i was on a really long trip i fave a feeling it might be a bad switch or loose connection somewhere anyone else have this problem before?
Old Jun 21, 2007 | 04:43 PM
midas6t6's Avatar
Default RE: starter switch problems
Sounds like the first place to check would be your switch for a looseconnection or broken wire.
Old Jun 21, 2007 | 10:12 PM
Illushun's Avatar
I have not come across that problem. But, it's easy to trouble shoot.
Old Jun 22, 2007 | 10:36 AM
yea it turns out it was a loose ground off of the starter and a loose wire in the switch must have been from my long trip so i went through the whole bike and tightened everything up properly so we are all good thanks for your input
Old Aug 3, 2008 | 09:30 PM
Darrylthenewf's Avatar
I must have the same problem. The solenoid works good with a charge across the terminals. So I am guessing it is the button starter. What should I look for in that assembly ???
removebeforeflight
Oct 13, 2014 10:16 AM
Bryantsito
Mar 12, 2012 04:50 AM
coldflood
F2 Tech
17
Aug 12, 2011 02:53 PM
Survivalism
Jan 29, 2011 10:18 PM
