The ridiculously long clean-up thread (4-20-08)
#91
#92
#93
#94
RE: Finally got a big bike
Well I didn't get to ride for a long time, but I did enjoy myself! As good as could be given all the sand on the streets.
I do have a question though. What temperature do your bikes run at? I was consistently around 230-240. I was thinking that maybe it's possible the fan isn't coming on when it should given the dead battery? I dunno. I checked the water pump and thermo, but I didn't test either - other than poking and prodding. Everything seemed normal. Coolant is fresh and full.
I did have the radiator cap off to try and see the coolant cycling but it would overflow first. Is that telling me that it's not cycling? I never had to check the F3 or F4 so... ?
Manual says it could be clogged passageways or air in the system. Guess I'll check that tomorrow. Probably go see Mike at Honda Tuesday because they're closed Monday...
#95
#96
#97
#98
Oh my gawd...
I forgot to fill the radiator back up after flushing. It dawned on me after I bought a battery today and went to get the bike. Ran at around 160-180 degrees...
I have a question for ya'll...
Since I've got that spanking new battery and I need to track down some possible electrical problems, can I just run my bike off of my trickle charger? Never thought about it, but I don't want to tax this $127 battery the second day I have it.
Thanks for any help!
#99
Well I've got a bad ground, or a short somewhere.
I rode yesterday for a couple of hours, then today I went for about a 20 minute ride. An hour later I took off again and made it all of a mile when I noticed the gauge cluster had no power, then the bike died. I unplugged the HID and turned the key - cluster back on. Still couldn't fire it up but I push started it pretty easy.
So now my battery is charging again and I really hope I didn't just jack this thing up. It wasn't cheap for a battery.
I guess first thing I'm going to do tomorrow is make a good ground for the HID and see if that changes things. If not, then I know there is a short somewhere, right?
Something is draining the battery - would a bad ground do that, or is it a guaranteed short?
Also, could the fact that I have no signals plugged in affect anything? Also, I noticed yesterday that my taillight is no more. Plugs/bulbs look good. Didn't notice anything off on the harness when I took my subframe off soo... ?
Looks like I've got some electrical issues to resolve.
#100
Well, another Homer Simpson moment...
"Doh!"
The "short" turned out to be my doing. As Irushed to put it together the other day, I forgot to reconnect of the the connectors on the rectifier. Problem solved!
I've got allof the sratches and holes filled, I just have to wait for them to cureand then I'll hit them up with the sander and get the primered. Finally the bike's body will be coming together and lookinglike a real bike again.
I also did some tweaking on the upper stay, it was off a bit. After only ten minutes or so I wasable to get it, from what I can tell, perfectly!
One more thing -I remembered I had an old LED taillight with integratedturn signals from my F4. Well, I wondered if I could remove those LED's from theboard and sure enough, I did! Here is a pic of some of them, I took the LED's and the resistors from the old taillight. I bought atoggle switch and I'm going to use the LED's for either demon eyes, or peg signals. Haven'tdecided but I'm a bit hesitant to crack open that headlight housing... anyone ever done it before?
Here are the LED's
"Doh!"
Here are the LED's
