Please help with oil change question!!!
Old Feb 25, 2011 | 10:13 PM
1 SiCk G's Avatar
Default Please help with oil change question!!!
Sorry I know this is a stupid question but i never did my own maintence and now i purchased Repsol 10w40 full synthetic oil for my 01 cbr929 .. is this good oil??? also i am having a horrible time finding the drain plug for the oil... can anyone help me find where to drain the oil from!!!!! pictures greatly appriciated!!!
Thanks in advance
Old Feb 25, 2011 | 10:39 PM
vwmaniacvr6's Avatar
There is a sticky to download the service manual at the top of the forums, if it isn't working anymore I can put mine up as a torrent if needed. It will show you this as well as many other fun things to do, like change out your fork oil. I personally use Shell Rotella T 5W-40 in all my bikes, the one in the blue bottle. You can get a gallon for $20-25 depending on where you buy. It's a diesel truck oil that has no friction modifiers and puts up with shear very well. Me and my friends switched to it after researching oil analysis reports from other riders that did the same. I've got nearing 27k miles on my bike, bought it with 8k after a stunter wrecked it, and still on the factory clutch with no signs of slippage. Since I can use it in my Jetta TDI as well I have a cabinet of filters and usually 5-10 gallons on the shelf for the car and my 3 bikes. Makes an oil change on any of them a true 10-minute job because I only go to the store for supplies once a year.
Old Feb 26, 2011 | 05:46 AM
txsmainevent's Avatar
Ok since you still have no answer to drain the oil......
Go to the right side of the bike to the right side lowering fairing(which you should remove to get to the oil filter). Go straight down to the oil pan. It is a 15mm bolt. Its the only bolt on the pan that is that size and the other ones are like 10mm. You cannot miss it. If you need me to snap a pic then let me know.
Old Feb 26, 2011 | 12:00 PM
So catty, wtf?
Torque the bolt to 29Nm/22ft-lb when you put it back on. The pan's aluminum so easy to strip and cause a bad week. That value is also in our excellent shop manual we have for free that everyone should download when they join the forums.
Old Feb 26, 2011 | 04:38 PM
1 SiCk G's Avatar
thanks all the only manual i found was all crooked and scanned horribly so its not even worth printing does anyone have a good copy of one a link would be greatly appriciated... and i still cant find it am i that retarded
Old Feb 26, 2011 | 05:46 PM
http://www.stephygee.com/929RRmanual.zip
Old Feb 27, 2011 | 08:49 PM
1 SiCk G's Avatar
got it... all good thanks alllll close this up mods.... this was all because i was taking apart my bike to get it painted so i will make a different thread with a few more questions thank u all for helping me out!!!!
close this up!
VP
Jan 8, 2009 09:14 PM
itgbudeev
Jun 3, 2008 04:35 PM
hoopster3
Mar 18, 2008 05:59 PM
600f2supersport
Mar 8, 2008 12:54 PM
gunrman13
Jul 8, 2005 02:22 PM
