New to this forum. Idle question
Old Mar 3, 2006 | 07:39 PM
seditionist's Avatar
Default New to this forum. Idle question
This is my 1st fuel injected bike, and my first litre bike. I just got my 929 two days ago, It cam with a full two brothers exhaust. I know I need to buy an air filter and power commander. But how do I adjust the commander? And I also want to know what your idle rpm is? The rpm on my bike when I am In neutural is 1k rpm. It that normal? The bike I had before was a zx6r 2000 model and its idle was 1.5k rpm. If it is lower than normal how may I fix this? I know I should get a valve adjustment but yeah... how else can I fix the idle? If it is low.
Thanks guys
Old Mar 4, 2006 | 02:58 AM
929_erion's Avatar
Default RE: New to this forum. Idle question
My 929 idles at 900.
Old Mar 4, 2006 | 12:13 PM
Deer_N_Beer's Avatar
your idle adjustment is ...when your sitting on the bike...look just behind inside the mid fairing....there will be a little black round **** that you twist......just above the motor.......this turning it clockwise will increase idle speed....hence, counterclockwise will decrease the idle.....
Hope this helps cover the idle part anyway...its too easy
ooops.....its on the left side...when on the bike...forgot to mention that
Old Mar 4, 2006 | 01:14 PM
sixs929's Avatar
Factory setting is 1200 plus or minus 100, so 1100 to 1300 is OK. I like it idling on the high side, so I set mine at 1400. Helps keep geek newbe's like me from stalling at stop lights, which is embarrassing when you are in full riding gear on a world class race bike - I suck, what can I tell you.
Old Mar 4, 2006 | 03:56 PM
Haha, Yeah Im not use to this bike yet I have stalled a couple of times, I am trying to get the hang of the powerband. Its a whole lot different than my zx6r was.
Haha thnx for the idle switch thing, I am going to go check it out now.
Old Mar 5, 2006 | 03:16 AM
sixs929's Avatar
One time I stalled the freakin thing at a light, and I was facing DOWNHILL, and I mean STEEP downhill!!! I let off the brake and glided away while I started it again, like "Hey, I MEANT to do that....".
Old Mar 5, 2006 | 05:54 AM
Haha rofl, good ****... so basically you busted a push start :P. or somthing. Haha good stuff man.
Old Mar 5, 2006 | 06:31 AM
Calkidd's Avatar
ORIGINAL: seditionist
What do you mean by "Cam"? Do you have after market cams installed? If so a power commander is a must and you could stand a chance of running lean with out it.
Old Mar 5, 2006 | 03:32 PM
I just spelled came wrong, ( it came with a full exhaust ). I have bad typos sometimes rofl. Sorry for my typing errors.
hawkwind
Mar 27, 2013 12:07 PM
Tactician
Sep 28, 2011 08:49 AM
1iwilly
Jul 28, 2010 12:12 PM
Cro
Aug 25, 2008 06:02 PM
pr0jktmayhem
Jan 9, 2008 07:16 PM
