LED taillight wiring problem
Old Jul 24, 2008 | 02:05 PM
Ghostz28's Avatar
Default LED taillight wiring problem
i bought this LED taillight from ebayt: http://cgi.ebay.com/ebaymotors/_Moto...3756.m14.l1318
and now I cant get it wired up at all. the blinkers are going, and the brake light is working, but i cant get light when the brake isnt engaged and the ignition is "on" and anyone help? I've tried all wires to my knowledge, maybe i have a defective unit?
Old Jul 29, 2008 | 03:22 PM
Ghostz28's Avatar
Default RE: LED taillight wiring problem
bump
anyone? I cant ride at night till I fix this. actually I shouldnt be riding at all without it working 100%
Old Jul 30, 2008 | 05:12 AM
mikey1297's Avatar
i have that same light, but i wont be able to look at my bike untill tonight to give you some help
Old Jul 30, 2008 | 09:02 AM
vwmaniacvr6's Avatar
Do you need a taillight initgration unit? I removed a box from my bike to put standard turn signals on that controls all that.
Old Jul 30, 2008 | 01:28 PM
Ghostz28's Avatar
I might. See it didnt come with any instructions. but my main problem is that I cant get a steady +12V out of any wire when the ignition is on. It only supplies voltage when the brake is pressed. I'm thinking of running a 12V wire from the headlight. it should still be well within the fuse's capabilities.
Old Jul 31, 2008 | 04:27 AM
mikey1297's Avatar
you dont hve to do all that and no you dont need a intergration box. but i still havent got a chance to look at it though
Old Jul 31, 2008 | 07:25 AM
If it helps any, here is the wiring back there:
Green - Ground
Orange - Right Signal
Light Blue - Left Signal
Green/Yellow - Brake
Brown/White - Running Lights
Old Jul 31, 2008 | 11:56 AM
Dizzymofo's Avatar
I have that same taillight but smoked. Funny thing is when I bought my bike the brake light didn't work and the turns were clipped. When I installed this light (I got instructions and resistors) I had to rewire the front switch all the way back (front lever, to the battery [constantly getting power], to the taillight). Now when I start my bike the headlight doesn't turn on and the amber signals are constant (no red lights, just the amber bulbs). After the bike warms up it goes to how it should be and the headlight and gauges and everything else light up. I think my battery is just needing replaced, which I was thinking before I purchased the bike since it was sluggish starting up.
Old Jul 31, 2008 | 02:29 PM
skubysnak's Avatar
ORIGINAL: vwmaniacvr6
Green - Ground
I have the exact same tail light. Came with no instructions as well. I followed the wiring per vwmaniacvr6. No need for integrator unit. Works fine.
theadamie
Mar 9, 2014 01:32 AM
ryan.boxing2262
Aug 21, 2012 11:58 PM
mbison83
Dec 4, 2011 08:29 PM
Bklynjoker
Jul 18, 2007 11:43 PM
Viper1994
Aug 3, 2005 10:17 PM
