Just bought my first sport bike.
Old 07-17-2012, 05:19 PM
Nulltone's Avatar
New Member
Default Just bought my first sport bike.
I just purchased my first sport bike last week. I've been riding a 96 HD for a few years now, I've always wanted a sport bike. Last week I bit the bullet and picked one up off of craigslist. The bike seems to ride nice and LOTS of power. I had a few questions about things I found wrong w/ the bike. I am a Volvo diesel master technician, so I know my way around engines pretty well.
First thing I noticed once I got the bike home was when I run it on the swingarm stand, w/ the clutch disengaged the bike seems to rumble, then when I pull it in it stops. This isn't as noticeable when the bike is on the tires. Almost sounds like a bad bearing but I'm not sure yet. Haven't removed the covers yet.
Another thing I noticed was the engine sprocket cover was missing and the case was broken off. It is not leaking oil but it leaves a hell of a mess w/ the chain lube flinging around. Is this something I need to worry about?
After finding these few things wrong w/ the bike, I'm worried about riding it. Is there anything else beyond the issues I've found I should be looking out for w/ this bike? I'll try to get some pictures of the bike up here and maybe someone can spot some of the mods done to it.
Thanks for any info posted
Old 07-17-2012, 06:21 PM
74demon's Avatar
Is the chain moving when it rumbles? Look at the rubber chain slider around the swing arm. The chain slides on it and will rumble as is runs on the ridge. That's normal. Make sure it's not worn through causing the chain to grind up the swing arm. Plan on replacing it with chain replacements. Also, make sure the links are in good shape and lubed up.
It probably had a chain explode. It will make a mess without the cover, but what can you do if the bolt holes are gone...
Let's see those pics!
Old 07-17-2012, 11:09 PM
crazie929's Avatar
mine has the same rumble with the clutch disengaged. not an issue.
clean the grease off the chain. i mean completely clean. run it for about 15 minutes straight to heat up the chain nice an good and then lube it up. but DON'T over do it. the heat will allow the grease to stick more without slinging.
Old 07-18-2012, 07:51 AM
drew929rr's Avatar
it very easy to think something is wron with ur sports bike i was always paranoid lol but u should have a blast on the 929 just becarful u dnt do power wheelies by mistake thoughs bike wanna lift in 1st
Old 07-18-2012, 11:26 AM
Nulltone's Avatar
New Member
I'll post some pics tonight. Thanks for all the info.
Old 08-05-2012, 01:16 PM
johnnyboy's Avatar
Congrats on your first sport bike and welcome to the forum!
J.P.
dnew1994
10-04-2013 03:20 PM
greentowtruck
08-19-2013 09:54 PM
F4tty20 00
01-16-2012 11:26 AM
hunterdogbr549
11-17-2009 05:50 PM
Shocktroop
01-27-2008 01:21 AM
Quick Reply: Just bought my first sport bike.
