HTEV & Servo
Got the valve in hand getting my ducks in a row to weld so I measured up the flanges and they are the same per side. I do not see how the rear section could be moved back 4 inches to take up the space though. The diagram shows midrange to be 4 straight through tubes and top end to be open like a crossover or x pipe. I am putting mine at 4 straight through. Think it allow for smoother flow instead of an interference in the middle. Now thatr it is in hand it all makes more sense. I assumed it would be some sort of butterflies but actually is a big cast piece. Seems to be a waste to me. Will find out tonight.
You don't want to do the 4 straight - if so there's no real purpose in doing what you're doing. That's how it is before it's opened at around &K rpms. If you look on the end (exterior) of the valve, you'll see two notches. One is a wide one, the other is narrow.
Tack weld it in place with the wide notch at 12 o'clock. And as far as the weld - just tack it from the outside (don't even have to remove the valve housing, just the silver cover on the front) with a single small weld.
Already tacked it but doesn't mean I can't cut it loose and turn it. Why do you say to leave the opening between the four tubes? I thought that may cause turbulence and being the Hass is just 4 straight through....I guess cause thats how they engineered it for 8K+?? Will it act as an equilizer(crossover)?? Hey THX too for all your input.
ORIGINAL: sc929
However, I'm not sure if we have defied odds (because it sounds logical to lose some low-end), but I didn't see any adverse low-end and neither has any of the guys here that have done it. And again, even if you did a new map would help tons... (again, always does).
Yeah, break that weld and tack it the other way, otherwise you should never have touched it to begin with!
Good luck buddy - you guys are making me miss mine already...
Done deal. Idle came down a touch and is a little more irratic. Sounds more like a lopey cam. As for riding. Acceleration is much faster and pulls way harder. Might have lost a touch under 4K, but will be going -1 on the front to cover this. I was looking to lose on the bottom end after all the threads that say you will, so maybe just me but whether ornot it is so minimal and not really under 4 that much anyway.I left the pc3 with the same map and mayplay around with that later but works fine now.Noticed no change in tone or volume. No dead spots.
I did end up leaving the valve in the 4 straight through position. After much debate I decided if it ran like sht I could yank it and move it to the full open pos. (I already had it on when i realized Kid put his full open.) It didn't so will get used to it like this and then change it over to see the difference. This can be done on the bike now in a matter of about 5 minutes. I have some concern about losing more low end by having it at full open. Right now it is like having the header lengthened 4". Note the tubes in the valve are 1.4 and the head pipes are 1.5. Will try the other way and see.
Overall good mods for nothing but time. If you try it, mark the servo position first thing so if it moves it can easily be put back to home position. Will also bea check in the future if a code ever comes up. I didn't get one yet but didnt mark it so not 100% sure I got it right. On the flapper, didn't notice any more noise from the air box. Also the popping on decel seems a little louder and more frequent so do the PAIR if this will bother you. I dont mind it.
Sam built up a pigtail for me to connect to a working servo and with the 6 pin connector plugged back in, and the MIL light reset per manual, the flashing MIL light is now gone. Now that I am back to original electrical form, Sam and I are going to do some data collecting so he can get the parameters of voltage/current so he can build a circuit to simulate the servo.
Lots of good info and communication going on with the whole exhaust/valve/servo issue in the last few weeks and there is light at the end of the tunnel.
ORIGINAL: sc929
It seems you have gained a minimal increase for the amount of work you have done. I dunno - maybe it's me, lol. In any case I think really the whole point of this is to
1) keep the HTEV in a full open position
2) increase volume in airbox (which is what compensates opening the HTEV, IIRC)
3) bypass the servo motor
4) eliminate the ECU from tripping the "MIL 35 Code"
In any case - I HAVE SEEN THIS DISCUSSION IN A TON OF FORUMS, AND IT HUMBLES ME AT NO END TO SEE THAT THE FINAL, END-ALL DISCUSSION IN IT'S COMPLETION HAS CUMULATED IN OUR HOUSE!
Awesome work Pitbike and Sam - you guys have done some great work and there has been so much learning going on for everyone for such a PITA problem that has, until now - remained the center of much debate.
I think this thread will get very popular in the future, congrats to everyone who took part!
It should be noted, that so far - this is the cheapes, simplest alternative that I have come across. Depending on what this new pigtail ends up costing, this could be $25+ your time solution,not a quick-fix.
I don't think I see the whole picture from your point. Like I said I woulod have opened it up all the way but already had it on the bike and will try the other too. It is too easy not to. I don't think the flapper mod does a whole lot to start. The point of any aftermarket exhaust is to have open free flow. With the Hass you have basically longer head pipes. Also at midrange position same as the Hass with a slightly smaller tube in the end. 1.5 into 1.4 then 2 into 1. With the valve full open you have 1.5 into 1.4 with an open area the back to 1.4 to 2 to 1. I got to believe this is an area for turbulence and that should cause backpressure. I am guessing it doesn't much because thats how it is when the engine is at top end. I am going to try it after I get a feel for this way. I am not sure it will matter much. I gotta believe with the results we got this whole setup was an emissions thing more then a help with the low end thing. Like I said I don't think I see where you are coming from and surely not trying to be a dick avbout it. 4 through is way better then 4 into 2 like orig low end. I just dont know that there will be much difference in the way I got it and how you have it. Will find out though. You know on all the threads I read on this and a lot there was a lot of different methods for the mod, but nobody got as deep as the pipe position and overcoming the servo, whatnot. So you know +1 from me too, thx to both of you and all who contribute. I post up the results of the flip when I do it.
