How to remove the tail faring on a 929rr
Old Apr 6, 2013 | 09:16 PM
74demon's Avatar
Default How to remove the tail faring on a 929rr
By request of a member in need, this is how to remove the tail fairing on a 01 929rr.
Remove the seats. The front seat has an Allen bolt on each side. Lift the rear corner of the seat to access them. Be careful not the lose the shoulder washer.
To remove the rear seat, remove the "Frankenstein" bolts and spacers from each side and the 2 10mm bolts and nuts front the center bracket and detatch the spring.
Remove the 4 plastic rivets, 2 on the underside and 2 from the front.
Remove the tail bulbs from the lens and release the harness from the holding tabs.
Remove the 2 Phillips screws.
Gently flex the front outward and lift the fairing off. You will need to work it around the R/R on the left and the wiring harness on the right.
....And it's off. Total elapsed time is was less than 10 minutes.
Install in reverse order.
Old Feb 4, 2020 | 09:21 AM
Golfnut's Avatar
Is there a thread with how to remove the front fairings?
Old Feb 4, 2020 | 02:28 PM
74demon's Avatar
Haven't seen one. Which are you trying to remove?
They are pretty easy to get off. All the bolts and clips are easy to spot, except the one behind the headlight for the nose fairing. Take off the windshield to get at it.
Old Feb 4, 2020 | 02:41 PM
Golfnut's Avatar
I don't know that I need to get the nose fairing off. I'm got the bike in November. I plan to flush and change coolant as well as oil and filter. I'd like to clean a bit under there as well, although with only 7k miles on the bike, everything looks new.
Do the clips break often? Should I but a few extra? I know on the older cars I've worked on the plastic gets brittle and though designed to pop off they often crack or break.
Old Feb 4, 2020 | 03:46 PM
74demon's Avatar
Having extra clips never hurts....
pittsm
How-To: Mechanical
65
Oct 27, 2021 04:12 AM
Blue Fox
How-To: Mechanical
May 25, 2011 03:30 PM
jondevos
Dec 3, 2010 10:30 PM
ze9900
How-To: Mechanical
Sep 4, 2010 07:45 AM
bigcha40
Jun 10, 2007 12:35 AM
