How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
How To: Install pimpbike.com 03-04 600rr undertail
Old May 13, 2010 | 11:38 AM
ze9900's Avatar
Default How To: Install pimpbike.com 03-04 600rr undertail
Recently I purchased a pimpbike.com undertail for my 03 600rr, I decided to do a write up on it for anyone else interested in them.
Everything that came in the box when it arrived:
First remove the seats:
Next remove the rear plastic four bolts 2 under rear seat 2 lower end of plastic:
Then remove the ugly mudflap and the metal brackets total of 8 bolts 4 on the mudflap and four on the metal brackets (save 2 of the bolts from the metal brackets):
Remove the passenger pegs four bolts:
Here is where it gets a little tricky the left side undertray has to be dremeled a little bit
I marked where it needs to be cut:
After I cut it:
Then install brackets to undertray:
Install L bracket to bike where the metal bracket was removed with the bolts you kept before:
Then wire up the turnsignals (Blue to Red / Orange to Red / Green to Black(for both sides) (I used the original plugs from the factory turn signals) and plug them in to make sure they work:
Bolt up undertail to L brackets and re-install passenger pegs and plug in turnsignal plugs:
Then just bolt the plastic back up and reinstall seats and your all done:
Before and after:
Size:  73.6 KBName:  102_1360.jpg
Now to uninstall it and have it painted
PossibleOne
Dec 29, 2013 12:06 AM
itsme71190
Mar 18, 2011 08:16 AM
harlowz
Sep 30, 2009 11:59 PM
nidiascro
Feb 18, 2009 01:07 PM
jessej05
Mar 12, 2008 12:44 PM
