How To: Install pimpbike.com 03-04 600rr undertail
17 Attachment(s)
Recently I purchased a pimpbike.com undertail for my 03 600rr, I decided to do a write up on it for anyone else interested in them.
Everything that came in the box when it arrived: Attachment 56054 First remove the seats: Attachment 56055 Next remove the rear plastic four bolts 2 under rear seat 2 lower end of plastic: Attachment 56056 Then remove the ugly mudflap and the metal brackets total of 8 bolts 4 on the mudflap and four on the metal brackets (save 2 of the bolts from the metal brackets): Attachment 56057 Remove the passenger pegs four bolts: Attachment 56058 Here is where it gets a little tricky the left side undertray has to be dremeled a little bit I marked where it needs to be cut: Attachment 56059 After I cut it: Attachment 56060 Attachment 56061 Then install brackets to undertray: Attachment 56062 Install L bracket to bike where the metal bracket was removed with the bolts you kept before: Attachment 56063 Then wire up the turnsignals (Blue to Red / Orange to Red / Green to Black(for both sides) (I used the original plugs from the factory turn signals) and plug them in to make sure they work: Attachment 56064 Bolt up undertail to L brackets and re-install passenger pegs and plug in turnsignal plugs: Attachment 56065 Attachment 56066 Attachment 56067 Then just bolt the plastic back up and reinstall seats and your all done: Attachment 56068 Before and after: Attachment 56069Attachment 56070 Now to uninstall it and have it painted :) |
nice i was wondering how an undertail would look on our bikes and now i gotta bet one.
