HEADLIGHT PROBLEMS
Old Aug 26, 2007 | 06:10 PM
mikey1297's Avatar
Default HEADLIGHT PROBLEMS
All 3 headlights are not working nore are the blinkers and the illumination on the gaugesi checked the fuses there all good and the bulbs are good i check the power going to the headlights and they all have power on them but it has power on both wires i checked the starter switch and all 4 wires are still soildered on i need a wiring diagrahm but i cant find one anywhere i think its a grounding problem but i cant find it any help would be much appreciated.
Old Aug 26, 2007 | 08:44 PM
mark5009's Avatar
Default RE: HEADLIGHT PROBLEMS
You can get the wiring diagram here
http://www.fireblades.org/forums/hon...gram-size.html
Hopt this helps
Old Aug 27, 2007 | 01:36 PM
Ripper44's Avatar
I had the same prob last year it was a ground issue we just made a new ground wire my dad helped with it (actually did all the work) seemed like a reasonably easy fix, but i dont really know much about wiring. Your deffinetly on the right track
bigboi18184
May 10, 2009 11:08 PM
xmurfx
May 9, 2009 04:03 PM
Ace_f4i
Mar 20, 2008 07:51 AM
cbrrrfan
Aug 25, 2007 10:33 PM
lldreams
Apr 10, 2007 03:48 PM
